OP25 Just stopped working...
ewh01
vineland, nj
#3
pi@RadioPi:~ $ sudo lsof -n | grep LISTEN
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
Output information may be incomplete.
cupsd 438 root 6u IPv6 17063 0t0 TCP [::1]:ipp (LISTEN)
cupsd 438 root 7u IPv4 17064 0t0 TCP 127.0.0.1:ipp (LISTEN)
vncserver 498 root 11u IPv6 17103 0t0 TCP *:5900 (LISTEN)
vncserver 498 root 12u IPv4 17104 0t0 TCP *:5900 (LISTEN)
sshd 504 root 3u IPv4 15969 0t0 TCP *:ssh (LISTEN)
sshd 504 root 4u IPv6 15971 0t0 TCP *:ssh (LISTEN)
ewh01
vineland, nj
I tried to connect to 192.168.1.178:8080
192.168.1.178 refused to connect.
KA1RBI
Portage Escarpment
ok thanks - this is indeed puzzling. The two commands don't appear to show any listener on 8080.
Let's have you try changing the rx.py command line "-l" parameter to listen on some other port, (try a few different ones), such as
-l http:192.168.1.78:8090
Max
p.s. ooh - also noticed a discrepancy in your posts - which could cause this crash (if not a typo in the post)- check the IP address - you've posted it a couple of different ways (192.168.1.178 versus 192.168.1.78)
ewh01
vineland, nj
Here is :8090
pi@RadioPi:~/op25/op25/gr-op25_repeater/apps $ ./rx.py --args 'rtl=0' -N 'LNA:47' -S 1440000 -f 774.68125e6 -o -200 -l http:192.168.1.78:8090 -w -q 0 -T trunk.tsv -V -2 -U 2>> stderr.2
gain: name: LNA range: start 0 stop 0 step 0
setting gain LNA to 47
supported sample rates 250000-2560000 step 24000
As for the IP address, I had a static IP of .78 in the dhcpcd.cfg, but I hadn't assigned it on my router, so apparently another device got assigned that address. I changed the static IP to .178 and I can access via VNC again where I couldn't via the .78
ewh01
vineland, nj
And yes, I did a reboot after changing the static IP, and tried to run it again.
KA1RBI
Portage Escarpment
OK if your "-l" parameter is still set to .78 and that IP is now assigned to a different machine, that would explain the startup error 100%
Could I have you verify that the IP address specified in "-l" matches the IP address of the local machine - you can verify the IP by using the "ip ro ls" command. If the address doesn't match rx.py will fail to start.
Max
ewh01
vineland, nj
pi@RadioPi:~/op25/op25/gr-op25_repeater/apps $ ip ro ls
default via 192.168.1.1 dev wlan0 src 192.168.1.178 metric 303
192.168.1.0/24 dev wlan0 proto dhcp scope link src 192.168.1.178 metric 303
ewh01
vineland, nj
OK, so IMADUMBASS... forgot to change the start line to .178 D'OH!!!
Running now!!!
THANK YOU ALL
for you assistance!! Now to reserve the IP for this device on the router
