I have a source in Arizona who indicates his National Forest's comm guide and the Regional Comm Guide (Southwest Geographical Area Coordination Center - GACC) shows 172.2500 as the "South Kaibab" net. The "North Kaibab" net is still on 170.5500. The South Canyon (Saddle Mtn. vicinity) electronic site has repeaters for both the north and south nets. I bet this site can be received quite a bit south of Grand Canyon NP given the north rim is about 1,000 feet higher than the south rim.
This source also told me that the Coconino, Kaibab, Prescott and Tonto National Forests have reconfigured their repeater tones to conform with the NIFC standard, so that their Tone 1 (110.9) is the same tone on each forest and the same as the tones in California. Other GACC's have already completed or will be making the changes to the national standard in the next couple of years. The Southwest GACC Guide does not reflect some of these changes for some reason, but his forest comm guide does. The BLM Phoenix District (2 Field Offices) and the Colorado River District (3 Field Offices) have done the same. With a little searching the Apache-Sitgreaves and Coronado National Forests and the BLM Gila District tone list will be found to see if the south end of the state is working on this as well. The AZ DFFM may have had some non-standard tones for some of their repeaters and tac frequencies, but now are all from the standard list.
This reconfiguration of tones following a national standard is long overdue. Many USFS, NPS, USFWS and BLM units were using non NIFC standard tones and labeled them differently so that 103.5 was Tone 1 and then were numbered in an increasing frequency order or in some different manner. This does not match the national standard and NIFC issued a directive 2-3 years ago for all agencies to change their tone configurations. Disparate tones was an issue raised in the Yarnell Hill tragedy and one or two other fire investigations. ICS is supposed to be a standardized system and the tone situation is a part of this. For daily operations this is important as well. As an example, the Southwest GACC has a number of resources temporarily stationed there from other regions, especially from North and South Ops in California. Not having to reprogram all the tones makes things a lot simpler when arriving. Tone protection on the NIFC large incident comm system started about 4-5 years ago and were numbered using this now national standard.
If there is any interest in posting the tone lists from the Arizona fire agencies here, I might find time to post them. I don't know if the procedure there is to announce the name or tone of the repeater when someone initially makes a call. In California the procedure it to say, for example "Inyo, Rec 21 Tone 3." I've heard forests in other regions use the name of the repeater when making a call, for example, "Williams, Patrol 712, on Bill Williams." If the California procedure of just stating the tone number is the practice it would be helpful to know the tones each repeater is accessed with.
I know this is far more information than was asked for. I thought that sharing what my source told me would be useful info.
