Kantronics
AK9R
Staff member
Super Moderator
Central Indiana
Check speed, parity, stop bits.
AK9R
Staff member
Super Moderator
Central Indiana
Speed 9600,8,none,1
That appears to be correct. Are both the TNC and computer set the same?
What software are you running on the computer?
How are the computer and TNC connected?
bodnarp
Allendale, Michigan
Running outpost tnc and computer connected to pc via usb, tnc connected to ftm 400 via the radio cable for it. It woked a month ago then stopped
AK9R
Staff member
Super Moderator
Central Indiana
Whether you are using a UBS-to-serial adapter or you have a newer KPC3+ with USB on board, when you connect the TNC to the computer, the driver should create a virtual COM port. Have you checked to see if that COM port number matches the COM port setting in Outpost?
AK9R
Staff member
Super Moderator
Central Indiana
Other than cycle power on the KPC3+ and check all your settings, I'm stumped.
AK9R
Staff member
Super Moderator
Central Indiana
Don't take this the wrong way, but if removing/replacing the internal battery fixed the problem, then something got set in the TNC that caused the communications failure. Kantronics' firmware is pretty solid, so that leaves a power glitch or...
As I recall, Outpost has a terminal window where you can send commands to the TNC and watch the results. The Kantronics TNC firmware has a handy command called "DISP" for DISPlay. If you type DISP in the terminal window and watch the output, you'll see every setting in the TNC scroll by. If there's a way to capture that dump in the Outpost terminal window, you could save that information as a file and use it as a touch stone to go back to if problems develop in the future.
