KCH10 troubleshoot
Hi all,
I’m trying to switch the remote heads on my TK890, KRK-5 from the KCH-11 to the KCH-10. The unit powers up and I can transmit/cycle through channels just fine but I have no audio. I’ve checked that the programming is correct and there appears to be no damage to the cable or connection points. My initial thought was maybe a bad speaker but I’ve tried two different KCH-10’s and had the same issue. Any advice?
To use the internal speaker on the on the KCH-10, there needs to be a jumper in place between Pins 3 and 6 on the rear 9 pin connector.
