Keizer Police
plexus
Keizer , OR.
New to the Salem area , I have tried various freq. lists from web sites to program my Pro-94 for the Salem / Keizer area. I pull in Salem police
and fire, but Keizer police doesn't show. They list on the sites as the same towers, and the 800's lists are a bit differnt . Is there anyone from the area that might shed light on this for me ?!!
Thanks ..... plexus
By the way , I used to post in the Washington State forum ( Shoreline )
joescanner
Just another radio geek.
Gresham, OR
Keizer is on 800MHz conventional, if I remember correctly. I don't have the frequency/ies handy right at the moment, but will post them when I do. If you are on yahoogroups, you can check out http://groups.yahoo.com/group/nwscan and check the archives. It's been posted there a bizillion times.
DanRollman
Atlanta, GA
According to the new Northwest Frequency Directory 9th Edition (www.ScanOregon.com) the Keizer PD conventional repeater is on 857.4875 with a 114.8 PL Tone.
Dan
www.ScanOregon.com
joescanner
Gresham, OR
Yeah... my night away from home and I didn't have a copy with me(!).
joescanner
Gresham, OR
Thanks ..... plexus
Okay, here's the skinny, confirmed on a trip down south today.
Keizer PD is on the system known as "B Tower" in Salem. (The transmitter antenna is on top of a pole in the PD parking lot there). http://www.radioreference.com/modules.php?name=TRSDB&sid=114
(Make sure you get the frequencies for 'B' tower).
Keizer PD has several talkgroups, but appear to be dispatched on 57840. They do, however, have at least one conventional frequency that they use from time to time (see earlier post by DanRollman).
About the only other thing you will hear on 'B' tower is the sanitation department (water treatment plant up off Wheatland Road).
Hope that helps.
joe
plexus
Keizer , OR.
Thanks everyone, the conventional repeater freq. seems to have traffic although I havn't had a chance to confirm what I am monitoring . I have tried a " B " tower list , but I found two conflicting freq. lists so next I will program the one linked from from Joe's second post !
Thanks again Dan & Joe ... Plexus
MrBarbecue
Salem,OR
KEIZER POLICE TALK GROUPS
Hi. Just purchased a Pro-95 scanner from the RS on Lancaster near Silverton. I too had problems getting Keizer, until I re-read the manual and also entered in the Tower B freqs and TGs.
Now, I get Kilo units no problem. The TGS are:
57840, 57808, 57776, 57744, 57712 Tower B Freqs: 856.4875, 857.4075, 858.4875, 867.8125, 867.5500
Try those and you should be able to receive Keizer loud and clear.
plexus
Keizer , OR.
Thanks MrBarbecue , I used almost the same freq. group you posted except , I have ... 857.4875 where you have ...857.4075 . I will try with both and then switch the two. I do seem to pull in tg-57840 !
Thanks again .....Bruce
MrBarbecue
Salem,OR
Try these too Plexus
These are from the RS Police Call, 2005 edition. Here are some more TGs to try out:
57664 Keizer PD
57680 KPD F-1
57712 KPD Tac 1
57714 KPD
57744 KPD-Dispatch Ch.1
57904 KPD Detectives
You are right on the 4875, musta hit the wrong key. Sorry bout that.
