Dhubjr
I have had scanners/radios my entire life but the P25 stuff is new to me and still seems to be giving me a bit of a headache. I originally purchased a 436HP and after having issues with the Kenosha County Sheriffs office's simulcast system I returned it and picked up an SDS 100.
After hours of watching videos and browsing RR forums I have had good luck with the scanner on Lake and McHenry Counties in IL and Walworth and Racine Counties in WI but the Kenosha Sheriff is still just not right. Most of the time I am only getting half of conversations either at my home in Western Kenosha County or while I run around at work in Kenosha, Walworth and Racine counties. Most of my favorites lists were from the Sentinel database but I have added some channels manually via info from the FCC database but am still having issues. I have been toying with different antennas both at home and on the road, some do better than others but the Kenosha County Sheriff still seems to have WAY less traffic than every other county it borders and that makes no sense.
If anyone down here has the Sheriff's office nailed down I would love to hear how you are doing it. And on a side note I have another question. Are TGID's used in conventional P25 systems or only in trunked systems? It sounds like on a conventional system I should only need the control frequency/frequencies and NAC and I should be good to go but apparently not.
Over and out.
Over and out.
