SDRTrunk Missing transmissions guidance
dave3825
Suffolk County NY
I noticed I am seeing some Sync Loss - Bits Processed messages in the Messages tab. Is this normal? If not, what should I look at to resolve this?
Post a pic of each tuner in the tuners tab.
Your not getting a great signal. Click the tuners tab and see what the ppm (measured error) is on each dongle. If 0 or close to zero, try adjusting the gain.
D3m0nicSoul
Looks like the control channel randomly goes idle then reconnects but logs that error. I tried messing with the gain but it won't stop.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
I'll ignore Camden City for now. It looks like in the current Beta 3 I can set the frequency on the specific tuner so I did this for the first 2 you recommended.
Is the Max Traffic channels setting per tuner or global between all tuners? Seeing my response above can I just set this to 24?
Side note I noticed I am seeing some Sync Loss - Bits Processed messages in the Messages tab. Is this normal? If not, what should I look at to resolve this?
Yeah I guess i sort of messed with that. I believe max voice channels is set per system, so just in one place. 24 would be the number.
As far as sync loss - I'm sure there could be various reasons -- poor signal, computer doesn't have the nuts to process everything needing processed, some issue with USB bandwidth. I really couldn't tell ya. Do keep in mind there is an actual SDRTRunk group on Google Groups. You can ask your questions here, certainly, but you may also want to look for answers to questions from the actual Google group as well.
