jasej
Hy My friendIs the radio programmed with any channels? What does the screen say?
This part makes us wonder:
" The data cannot be read from this transceiver because
the data include a funtion which cannot be configured whit this FPU "
What feature it is that the KPG-D1N can't handle?
I've never seen this come up before, but all the radios I'm using were purchased new.
If it's a "K" market radio, that's North American market. Can't recall where it tells you what market the software is, my programming software is on a different laptop. Won't be in the shop until Friday.
OK, so questions:
Did you purchase these radios used?
-or-
Do these radios belong to an agency and are you trying to modify programming?
So, like I said, K is N.A. market.
KPG-D1N version 5.20 is newer than the 5.10 firmware version in the radio, so that's not the issue.
If you purchased these used off e-Bay, maybe return them.
Since I have trunking system keys, I've never run across the key issue before, so not sure what it would error out as. Might be the cause, but I'd not be able to check that easily. Maybe someone else can.
NX-5700 K, as the software shows, and the radio label says
The radio has many channels programmed and on one channel , the display shows TX:097 RX:097 and in the upper right corner it shows the small letters ANA-N Zone 2, I think that in that zone two, there are 97 programmed channels available.
The two radios, there are only two, I'm sure they are from the USA, there they were bought used, second-hand in a place that sells that type of used devices. This purchase is final and does not accept returns, that's how it is in those types of places
These radios belong to a person who is only interested in using them for their own use, they are not interested in what is programmed in them, they need to program their frequencies
Now, I have KPGD1 version 5.20 and the radios have firmware 5.10 on them, it should at least overwrite and delete the data without a problem! As I mentioned, the radios does not have a read or write password, both are uninhibited.
I just need to try with the KPGD1N, but I don't see any difference with the KPGD1, in terms of just overwriting, we will see that
Than you my friends, for your answers
