Correct I have the radio programmed with 3 of the same frequency, each of them has a different power rating. 1 is High 2 is Med 3 is Low. I want to know if theirs a way to actually lower the wattage. Example High power is about 45watts and my question is if theirs a way for high power to throw 40 watts instead. So pretty much manually lower the wattage on each mode.
You would need a professional service monitor to do this correctly, but a digital watt meter, and putting the radio into test mode (CTRL-T)
and then adjusting the power output for each level.
NOTE! be careful on how low you set it, this can be damaging to it also.
Like the GM300, if you set it too low, like an irlp node FBX, you can wear out the power amp just as quick because its not within
the normal operational current it needs.
