Kenwood Site Roam
70cutlass442
I am unfamiliar with the the settings in the site roam and need to roam between three sites. Beacon is set to 6 second intervals. Attached is the current setting... Could someone better explain what the different settings do?
buddrousa
I have 2 Systems 1 5 Site and 1 7 Site with similar settings. With me it is best guess what the settings mean.
Drop out time loss of beacon time?
Dwell time how long it looks at sites for signal?
Quick site level this is minimum signal when checking for sites?
Standard level?
Site roaming resume the signal it will search for another site?
AM909
Radio/computer geek
SoCal
See if you can find the "NX-1000_Function_List_FUNC_K_E_C_M_X_Ver330.pdf". The function ref is often more useful than the formulaic language they use in the KPG help files. Pages 148-151 in that version are relevant.
70cutlass442
I have installed several Site Roaming systems--both NXDN and DMR. Have left the subscriber units in default settings and have not had any problems.
The problem is, on Kenwood is they are simply left in the "off" position. From there, you change to your desired settings.
70cutlass442
ramal121
Lots and lots of watts
Calif Whine Country
As in regular scan Dropout Delay and Dwell is the time site roam is suspended when receiving or transmitting.
If Quick Site Roam is used scan will stop and select the first channel that exceeds this level. In your screen shot Standard Site Roam is off, therefore roam will not happen until it sees a level better than this. Helps when there are many sites to scan. For 3 sites not much of an advantage.
Standard Site Roam is where the radio scans all sites and picks the best of those that have the threshold level or better. If you use both Quick and Standard then Quick must be a higher level than Standard.
Site Roam Resume is what it states. Must be lower than Quick and/or Standard Site roam.
If all selections are off it will still roam by using squelch level only.
wd8chl
So the normal default values should work for most all circumstances. I would set them to these values first and try that for a while.
