TK-762HG-1 will not key from microphone. PTT is being received on pin 26 of IC502, approx 3 volts DC with key open, 0 volts when mic button key is pressed. The RF section is working as the radio produces high and low power when using the KPG-56D SW test mode. D16 switches to TX when running TX test using SW test mode. IC-502 VCC checks good. The SW test mode must not use IC-502 pin 26 (PTT) as the voltage remains approx 3 volts when running the TX test. Radio passes receive tests, programs as expected, all front panel buttons function, the radio just will not key when using the microphone PTT button.
What else should I check?
Thanks.
Thanks.
