Kenwood TK-880 firmware compatibility
bbo14
Hobbs, NM
I have three KENWOOD TK-880-1 radios. I notice on power up they display "V 1.5209" for firmware version. These were on a passport system. So, some questions: I have KPG-56D V 4.01 software. I have FPRO. At present, I do not have the SJ software. I only need to program GMRS conventional frequencies and squelch codes in, no trunking. I need the proper firmware version to "downgrade" the firmware so KPG-56D will program the radios. What fimrware version do I need? Or in the alternative, is there KENWOOD software, (not Scholer-Johnson) that will work with this firmware? I have programmed TK-880's before (not recently though). I have the cable. Thanks for reading.
n0fwg
Minnesota
Yes you can change the frimware to a normal no SJ version, provided you can get into the firmware programming by holding down one of the keys (D?) while powering it up Radio will display prog 57600.
I do not have the most version # in front of me as I'm not at the shop.
You will need KPG49D to program the TK-880 radio, KPG-56D will not work.
bbo14
Hobbs, NM
Sorry I said KPG-56. I have it but I also have the proper KPG-49D software. I have read so many posts/forums/rants about these radios today I forgot which software I was talking about!!! I have FPRO so now I just need the proper firmware. Thanks for your response. Bob
bbo14
Hobbs, NM
I also now have KPG-63D (supposed to be proper sw version for trunking; used with fw 1.5xxx which is what these radios have). If I remember correctly, KPG-63D will allow conventional as well as trunked entries. Please correct me if this is incorrect. And yes, I would also like to obtain the proper FW for use with KPG-49D. Thanks for your insight.
bbo14
Hobbs, NM
I was able to read two of these radios today with KPG-49D. I was able to write to them, but got the message stating they are not version 2 and some features won't work. No xmit power out. One shows it's trying to transmit (got signal into my handheld). Other? Gonna have to dig deeper. I'll check for proper drive level at the input pin of the power "brick". If it's there, I'll pop the cover off and use a magnifying glass to try to spot the hairline crack in the solder land that sometimes plagues these radios and some Kenwood ham radios too (TM-231,TM-241 come to mind). If you no where to get the fw for version 1, I would appreciate it. Thanks again.
