Kenwood TK-890 to 8180 setup on motorcycle
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Thank you Ram,
Apparently there’s a few KPGs that are assigned to the 8180, I just grabbed the first. After installing the KPG-89D (there were 3: vanilla, v1.02, v1.10). One has to install as Admin due to its installation in Windows protected area.
So this looks like the right tool, next to know what function values are needed to run the remote front panel and PTT
All you have to do is install the remote kit. It is transparent to the radio.
Well for one you have the wrong software for that model. You need to have KPG-89DN to be able to program a 8180.
Sent from my Pixel using Tapatalk
Thank you Ram,
The KRK-10 cable handles the base to remote interface, and the accessory cable is for the headset and PPT switch, yes?
kayn1n32008
Sector 001
Yes. The ‘accessory cable’ will be the one that connects to the DB-25 on the rear of the RF deck. The remote cable connects to the front of the RF deck.
kayn1n32008
Sector 001
I see there’s different functions for Input and Output pins
DB-25 connections:
Pin 4: PTT(one wire here and the other to ground from the existing remote PTT switch
Pin 7: Ground
Pin 6: Mic (Tx audio from headset to radio)
Pin 17: Rx audio(from radio to headset)
In ‘Edit’ select ‘Extended Function/Aux Tab’:
Set DB-25 pin:
4: Input, Ext PTT
In ‘Extended Function/Modulation Tab’,
-MIC PTT: Mic Line=Connect, MI2=connect, DI Line=disconnect, QT=Yes, STE=Yes
-External PTT(Voice): Mic Line=disconnect, MI2=Connect, DI Line=disconnect, QT=Yes, STE=Yes
ramal121
Lots and lots of watts
Calif Whine Country
DB-25 connections:
Pin 7: Ground
Set DB-25 pin:
4: Input, Ext PTT
Pin 17 receive audio really doesn't have the nut to drive most helmet speakers. You would need to add an external speaker and tap into that for receive. If there is an audio amp for the headset receive you're good, but usually not. You can also add the KAP-2 board inside and switch speaker audio from the head to another connector that will come out the back of the radio by a programmed button on the head.
The MIC PTT line should have MI2 as Disconnect. You really don't want two live mics from one PTT source. Although if using the palm mic the helmet is probably disconnected from the bike anyway.
I picked up the Horn Alert/P.A. Relay Unit (KAP-2 : Option) new for $25 + SH, just as insurance per RAM’s admonition. Apparently that too is enable by the programming utility and has a pigtail cable that exits the rear of the radio base next to the accessory port.
Would a gracious forum moderator please remove the “890” from this threads title, as it was ignorance and a mistake on my part and is confusing to the content.
n3obl
ØAES-1024
PA
I would look for version 1.61 software. Thats one of the latest versions.
Getting there.
Tx/Rx checks out
Hmmm updating the radios firmware...
Wonder ifni need it
Unless the people you are working with require that you use some sort of radio ID/Push To Talk ID, like FleetSync or MDC-1200, do not use it. It'll just annoy the crap out of everyone else.
Basically what it's telling you is that the firmware in the radio is old and won't support MDC-1200. If you really need to have it, you can update the radio firmware.
But, best to leave things alone if it's all working.
“If it ain’t broke, don’t fix it”
Yup, I belong to that and the KISS club.
Thanks for the advice gents.
The KAP2 board comes soon in the mail.
I’m waiting on a fork base with a RAM ball, and an articulating arm to a 6.5x2” rectangular base to mount the remote control/display head to. Still need a helmet comms set and mound the radio.
I have two antennas, both in the 400-520mhz range, one is 2 foot or so whip with a spring winding in the middle, and the other a stubby 2 inch tall coiled one. Both work in the table, but I wonder which is better on the road. The whip looks cooler but makes putting a cover on harder.
Depends on what sort of coverage you are looking for.
The longer antenna will be more efficient and likely get you longer range.
If short distance communications is what you are looking for, the shorter antenna might be a better solution to eliminate interference.
"Better" can mean a lot of different things depending on what you need. I can tell you that a 2 inch tall UHF antenna is going to be very inefficient.
