Eng74
The command is still on Kern 5. You will here them on there during the swich from day to night ops, otherwise they are on tacs. Just crews and dozers doing the last line work and the work inside the line.
Why would I want to only feed the Kern dispatch channels when there is a major fire burning covering all of the NIFC channels and then some?
I understand you better now but I think you're unaware that Kern turned this over to a CALFIRE Incident Management Team. Type 2 I believe. But what I don't understand is that if it is a CALFIRE incident now why they are using federal frequencies. They are, by and large, using NIFC, USFS Tac, etc.... ... ... ...!
I understand you better now but I think you're unaware that Kern turned this over to a CALFIRE Incident Management Team. Type 2 I believe. But what I don't understand is that if it is a CALFIRE incident now why they are using federal frequencies. They are, by and large, using NIFC, USFS Tac, etc. They can also be found on VFIRE and VTAC. I've been listening to them all day with excellent reception.
_..._
The reason Federal frequencies are in use is this small organization called FIRESCOPE. After the disastrous 1970 Wildfires, Congress chartered a project to look at how better to manage fire. Eight Federal, State, and Southern California local agencies collaborated in establishing a number of standards and operating methods (including, among other things, ICS) which have become national in nature. One of the products was a common set of operating frequencies for large incidents, where USFS, BLM, CalFire, and then-OES contributed frequencies to the pool. In California, frequency assignments are normally handled by one of two Geographic Area Coordination Centers (North Ops in Redding and South Ops in Riverside), where the larger picture of making sure that Fire A's operations don't interfere with Fire B (or Fire C, or Fire D ...). (During very heavy wildfire conditions, frequency management reverts to the National Incident Fire Center in Boise).
So just because it is a "local" or "state" fire doesn't mean that the comm plan will be limited to the frequencies of the particular agency who is managing the incident. It is very much a collaborative effort aimed at safety on the line.
SOUTH OPS FREQUENCY PROCEDURE 2011
Frequency assignments and procedures for 2011 have four changes from 2010.
• The FAT I.A. Victor (am) frequency changed from 122.425 to 128.475
• The HMT, SMX, PRB, O22 I.A. Victor (am) frequency changed from 122.575 to 135.575
• Both secondary A/G frequencies have also changed we now have 166.8750 from BFL to SAC and 169.1125 from the Mexican border to BFL.
• Cal Fire has assigned their air tactics FM frequencies to their tanker bases zone of influence not to the ranger units.
AIR TO GROUND FREQUENCY NOTE: 170.000 IS THE PRIMARY A/G FREQUENCY ON ALL FEDERAL INCIDENTS. 166.8750 AND 169.1125 ARE SECONDARY A/G FREQUENCIES AND ARE COORDINATED BY THE GACC AND ARE NOT TO BE USED UNLESS AUTHORIZED BY THE GACC.
We have four pre-assigned Initial Attack victor frequencies, six pre-assigned Initial Attack FM air tactics frequencies and two I.A. A/G frequencies (shown below), those frequencies are for initial attack only. If the incident goes into extended attack the I.A. frequencies are returned to the air attack base for I.A. and a request to replace those I.A. frequencies will be sent to South OPS. Those frequencies will be utilized for the duration of the incident. Any frequencies not requested through SOPS are not authorized.
ALL FREQUENCY REQUESTS OTHER THAN THOSE ON THIS LIST WILL BE REQUESTED THROUGH THE NICC CDO FOR FEDERAL INCIDENTS AND THROUGH SACRAMENTO FOR CAL FIRE INCIDENTS.
Southern California OSC & Cal Fire Southern Region CSR
PRE-ASSIGNED AIR TACTICAL (VHF-FM) FREQUENCIES
Air Tactics 1 166.675 is assigned to CNF, LPF, INF, and CND.
Air Tactics 2 169.150 is assigned to BDF, SQF, STF, KNP, and YNP.
Air Tactics 3 169.200 is assigned to ANF, SNF, and SMP.
Air Tactics 4 151.280 is assigned to PRB, SMX (SRA FIRES),
Air Tactics 5 151.295 is assigned to CVH, SBD (SRA FIRES)
Air Tactics 6 151.310 is assigned to HMT, WJF (SRA FIRES) FAT
Air Tactics 22 - 151.2875 is assigned to RNM, O22
Air Tactics 23 - 151.3025 is assigned to PTV
Air Tactics 21 - 151.2725 is a GACC wide secondary air tactics
INITIAL ATTACK AIR TO GROUND FREQUENCIES
151.220 – Cal Fire
170.0000 – Federal South OPS GACC Wide
166.8750 – Federal BFL - SAC
169.1125 – Federal Mexican border to BFL
PRE-ASSIGNED VICTOR (VHF-AM) FREQUENCIES
135.975 - Ramona, Fox, Bishop, Hollister, and Porterville Air Attack Bases.
135.575 - Hemet, Santa Maria, Columbia, and Paso Robles Air Attack Bases.
133.425 - San Bernardino Air Attack Base.
128.475 - Fresno Air Attack Base.
PRE-ASSIGNED VICTOR FREQUENCY FOR THE SOLAR PLAN:
Air Tactics 7 (130.200) is ONLY to be used as the pre assigned victor frequency for all incidents included in the “SOLAR” Plan.
I do not have a current channel book at home the last one I have 169.1125 was not in the moto/kenwood/BK radios.
