Wouxun KG-UV9P Configuration
spiciacchia
So I purchased a slightly used Wouxun KG-UV9P on Ebay. It is in great shape, but appears to have had the preprogrammed channels and frequencies erased. There are only two frequencies programed in the radio. I am guessing they did a reset on the radio. I contacted the seller, and they never took a backup of the radio. So, does anyone know if there is a place where I can get a factory config file for the KG-UV9P radio, so I can restore the original configuration with all the channels and frequencies?
Thank You.
robertmac
Since frequencies vary greatly from area to area, you would have to get someone near you to help you program the HH. Not sure what frequencies you want or need. VFO should give you frequencies. If you are not sure what you are doing, don't transmit on a licensed frequency. But you might want to indicate the frequencies you need for your area.
spiciacchia
When you get this radio from Better Safe Radio, it comes programed with a ton of receive only frequencies and channels, like racing frequencies, airline frequencies, international space station frequencies, different government frequencies, etc. They basically allow you to listen to traffic on the frequencies. Then you can scan through them. Those are the ones I am trying to get. Now that I said that, I am thinking that Better Safe Radio may be able to send me that config file if there is no easy way to get it. If not, then I guess I am out of luck.
Frequency1
NYC area
Looks like Buy Two Way Radios sells the KG-UV9P right now.
On their website and page for that radio, you can click downloads, then you download KG-UV9P programming software. Hopefully this includes the channels you’re looking for.
**I didn’t download it myself, so not sure.**
