KNG-P800 won't power on
jkpugh1
I have a KNG-P800 that won't power on all of a sudden. Tried a new battery just as a matter of course. Also tried getting into bootloader mode by holding PTT and powering on, but still nothing.
Are there any other magic things I should try before having it serviced?
thanks!!
gesucks
Our Nation's capitol
If you have older firmware, and where using Rx only, the ID would be set to 1. Many systems send regular inhibit commands to ID 1. This will inhibit a radio even if in Rx only (not just BK but other brands using hidden TG method)
Newer firmware was supposed to change the ID when using Rx only to 0
jkpugh1
It's a totally legit radio on the network and not RX only, hence why I'd be surprised if it were inhibited. I was trying to do my due diligence since replacements are hard to come by in a timely manner here, and have had good luck with the bootloader and firmware upgrade path in the past fixing things.
n7maq-1
Oregon
thanks!!
Did you have the radio hooked up to the PC when you tried to put it into bootloader? IIRC you need to have the radio hooked up to the USB port before powering on for upgrades.
Jim
