KNG Programming question
22nineline
Looking at a used mobile radio. A KNG-M150, the owner did not program it so he can not answer some questions before I buy. I would assume they can set a password in the program so without it nobody else could program it. Is that right? Watched a bunch of videos and I know there is a password set to program from the keypad but nobody talks about the regular programming. Would guess it is just like a Motorola and anybody that programs it can set a password to keep others from changing the radio. Not sure if he can not tell me if I want to run the risk of buying it. And I do not want to spend $150 to buy the program to find out that was a waste as well. Been using Motorolas for a very long time. Started carrying the MT500 if anybody else on here can remember that far back. And at times I think being rock bound was easier.
22nineline
Seller had a guy that worked for a shop program it so he does not know if it has a password or not. Think he is being honest and I'd like to buy the radio but do not want to buy a brick or pay shipping to a shop and then fees to unlock if it is. Can anybody tell me I find it is locked can you use Wireshark to get the password if it ends and is password protected?
22nineline
Got the software coming soon and he is letting me try out the radio. Will run the numbers then. But can somebody tell me if there is a default password the software might use if nobody changed the one in the software and then check the box. I know I've seen it happen they check the password box and forget to see what the program sets as a default password
n7maq-1
Oregon
The only "default" password in a BK radio would be for FPP, and it is 000000. I have never seen or used a read/write password on a BK, just by their intended use on large multi agency events that is asking for trouble. If you do want to add a read/write password you can, it is labeled PC Access Password. If the radio you are getting does have a PC password I don't know how you could recover it, and no you can not just write a new codeplug without the PW.
22nineline
Thank you. Is there a way to program in a TX inhibit? Want to add the weather channels and do not want to key up on those for sure. Just got the software in today so just starting to look at it. Been looking at a few videos but have not seen how to do that. Did one video from BK that does a pretty good job going thru programming but did not see how to lock out the TX on a channel. Which I bet they have
n7maq-1
Oregon
Just type in 000.000 in the TX freq.
What version of RES did they send you? 5.13.xx has some bugs, we use 5.11.00 in the shop.
