KPG-112DN V2.33 & TK5320K
rkumetz
I read a TK5320K and programmed 2 new ones. Both have a continuous "beep-beep-beep-beep"
when they are on. They both pass self test and the batteries are charges. The radios read
out correct information.
What am I overlooking?
On a related note, how can I remove the channel knob stop that limits it to 16 channels
without destroying it? I want to add some extra channels but stick with 1 bank.
rkumetz
OK I solved the initial problem - Turns out that the radio that I read was the 400-470 version (guy who sold it to them was a ham) and the radios they have now are 450-512. Is there a way to copy the zone info so I don't have to re-enter it? Simply changing the frequency in the product info tab clears out all of the frequency info.
You should be able to open the file, then go up to the "Model" and click on "Product Information". You should be able to change the Frequency Range from 400-470MHz to 450-512MHz.
That will throw an error about some of the settings, but it's OK.
Note: This won't make a low split radio suddenly work as a high split radio, or vice versa. You are still limited by the radio.
2154
I was just about to comment back with your solution which you already figured out. I ran into this recently myself on accident and had the exact same problem on an NX-5800. I believe you can use a spreadsheet to do so but one of the other pros on here can probably answer that better than I can.
rkumetz
I tried that. I pops up a box saying that the configuration data for frequency will be cleared. If you say OK it clears all
of the channel data. If you say cancel it does nothing.
ramal121
Lots and lots of watts
Calif Whine Country
That and the fact that the model doesn't support zone merge where you can save a file of the merge or any type of export/import function.
In other words you are SOL. Start typing.
rkumetz
Fortunately you can open 2 instances of the software. If you change models only the channels are cleared so I brought the old and new up side by side and just started typing.
