KPG-180AP
SAFFA
World
Hi guys. I'm struggling a bit with kpg180ap otap software. I've used the kpg150AP quite a few times with no issues.
The issue I'm having with 180AP is:
I drag my kpg-D3N file into 180AP, the file appears on the window. I can then execute the otap to that UID. Now when I want to use the same file but add a different user ID. The option to add a new target is grayed out and for the life of me I can't find a away to do.
Am I missing something? I've read the manual but I can't find the solution.
kd4efm
EL98 Florida
You have to have individual files if I recall. I had that hassle one time. Don't use it anymore.
Sent from my SM-G935P using Tapatalk
SAFFA
World
I hope that's not the case.
In kpg150AP, u could drag 1 file across, and then add target radios by assigning the UID u want to change and the Alias, and then execute the OTAP and it would then write to those UID.
bdbrennan
GA
You can only add additional units in using the ID Management feature of D3. Import a base file, then open D3 and add your additional units. After saving, they'll show up in 180AP.
