KPG-49D on Win 11
atcsdeland
Deland, FL
Has anyone had tried or had any luck installing KPG-49D on Windows 11? If so, what did you have to do to make it work. Unlike Win 10, there doesn't seem to be an option to install in "Compatibility mode".
atcsdeland
Deland, FL
What is the software doing or not doing?
More information about your problem is needed for more help.
I get a window saying the Windows is unable to install the software. When I looked at the folder contents it looked like my version might be DOS based. Maybe this version is too old?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
It's been a few years since I've used KPG-49, so I just I stalled it on my windows machine with out issue.
I forgot to add, I installed V4.02. I can't test read/write, because I don't own any radios that use this particular software any more.
Motoflightmedic
ÆSØ
U.S.A.
There is a DOS based and Windows version of this software, you just need to use the Windows version if you haven't tried that yet. you may also have to upgrade to a USB programming cable if your PC doesn't have a serial port or can use a serial adapter.
hill
Middle River, MD
If you need a new cable Bluemax49ers is goto for radio programming cables. He is best stuff if you don't want to original.
Make sure to buy the FTDI version.
atcsdeland
Deland, FL
I appreciate all of the responses. I did get this straightened out by getting a Windows version of KPG-49D. Contacted mark at Bluemax49ers and he sent me a link. Another reason to do business with him-if you have one of his cables and need a different software he is happy to help.
