KPG D3n
Ret_Batt_Chief
Windsor,ca
Making my way through the KPG D3n software. Is there any documentation on the software. Help file is not great.
Still navigating the "systems" vs Zones. I see you can have 16 channels per zone. Does each zone need its own system? Personalities are the same as channels?
kd4efm
Florida
Not unless you have more than 1 system where you need different things.
System is where the freq and details go.
Zone/channel is where you make your channel order per zone.
If you have you button config set to channel, you can have up to 250 channels per zone, or 32 zones with 16 channels (unless you also have the 3000 channel option key installed)
Enjoy.
Ret_Batt_Chief
Windsor,ca
So Personalities are all the available channels within a system. Then you can assign "personalities-channels" to any zone?
