KSIC Site 121
WX4JCW
Stow, Ohio
FYI Sitting here in a rest area just east of Greensburg
867.1125 is coming in with a 99% decode rate showing site 121
No Activity though, So could 121 be The Kiowa County Site?
KAA951
Kansas
All the new sites are going in on locations where KDOT already has towers established on their 800 conventional system. There is no Kiowa County site.
http://www.radioreference.com/apps/db/?aid=587
Interesting you had decode at 99% for site 121 there- the site just to the south of Greensburg in Wilmore (Comanche County) uses 867.1125 as its primary control channel. Is there a possibility here that the Comanche site should be 121 instead of 119 in the database?
BTW the 851.00625 control channel listed in the KSICS database for 121 is not a valid freq. Nextel uses 851.0625, not sure if someone picked up one of their sites by accident.
n0lqt
Howe, TX
Actually I think 851.00625 is just the "base channel" in the frequency table for type II systems (ie Channel 00-0000 or possibly channel minus 1?) It is probably just there in the database as a placeholder.
Too bad we don't have someone over there with a laptop and Pro96Comm software.....
WX4JCW
Stow, Ohio
I Ran Pro96Com on it but it was not active at all, was in greensburg for 2 hours
I run US54 in the winter to Las Vegas and back to the east coast from california
so i will set up Pro96com and share what i have when i go through there.
but here is what i got
FileVersion:4
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 1B2
System Name : Kansas Statewide Interoperable Communication System (KSICS)
WACN : BEE00
Tower Number (Decimal): 121
Tower Number (Hex) : T0115
Tower Description : Site-121
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Wed Oct 22 19:10:40 2008
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625
01,762.00625,0.00625,30.00000,"Confirmed",0.00625
-Frequencies
#Format: Channel,Usage,Frequency,Input Frequency
"00-2577","c",867.11250,822.11250
"00-2625","a",867.41250,822.41250
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
116,"T0110",1b2,"00-2597",867.23750,"Preston"
118,"T0112",1b2,"00-2487",866.55000,"Sharon"
120,"T0114",1b2,"00-2609",867.31250,"Fellsburg"
130,"T011E",1b2,"00-2517",866.73750,"Site-130"
