Ksp post 9
Coburnsun
Ky
Noticed a few days ago 12/26/2025 ksp is not working at all on my sds200 have they changed something on their end or is my scanner not functioning right? Has worked fo a year or so flawlessly.
ofd8001
Louisville, KY
Do you have more than one site programmed for Post 9? There might be a site in your county that is the only programmed one. It could be having a "mechanical issue" and simply is out of service.
Usually most posts will have a transmitter in each county of their area, but on different frequencies. The magic of the system is that they all transmit on different frequencies. KSP radios will listen to all those frequencies and select the one it gets the best signal from.
So if you program all the frequencies (both A and B channels) for Post 9, you will probably hear something.
Coburnsun
Ky
Yea I’ve got several but the only one I’m close to is probably 4-5 miles & the rest are 15-20 miles. I’m thinking that one is down atm. Either that or my scanner has took a 💩
ofd8001
Louisville, KY
15-20 miles isn't too far away.
You can always do a weather scan as a quick diagnostic to confirm your scanner is receiving. (Probably a good many of the NWS transmitters are using the same towers as KSP though different frequencies, etc.)
Coburnsun
Ky
I done the update on my SDs 200 & im pretty sure the new firmware is the issue. Anyway to get the firmware that came on it from the factory
ofd8001
Louisville, KY
I kind of doubt it may be the firmware. When I upgraded firmware a while back, the scanner developed a clicking noise on conventional digital systems, KSP in particular. I rolled the firmware back and the noise went away. The Uniden folks did some work on the firmware and the latest version is working fine for me.
I get KSP posts 4, 5 and 12 here in Jefferson County, just fine with the latest firmware.
At any rate, if you look at the thread below, you will see somewhere, how to roll the firmware back to a previous version.
Coburnsun
Ky
IMG_6321.pngWhy am I not getting any sound from this frequency? Was working fine till after the update. Now it’ll stop on it but no sound thanks
iceman977th
Mess with the Bull. Get the Horns.
Banned
Catlettsburg, KY
Without seeing your config file or anything like that, there's no possible way we can help you to know if there's a config issue or something else going on.
That being said.. I wonder if they are doing work on this end to facilitate upgrades for SERVS. I originally only had 14B Ashland in my feed because there was no way to filter by NAC and keep WVSIRN out of the feed.. but I AI-coded NAC aliasing into SDRTrunk and re-added a bunch of 14, 8, and 9 towers, and I feel like there's more traffic now. So maybe there's some simulcast links down right now, or it's just that... slow.
ofd8001
Louisville, KY
I’m confused. You were mentioning KSP post 9. This is got ambulance stuff.
What one you really mean?
