KW TK890/790 Dual Brick Setup
nikronzo
4.X SloppyCast
Need someone to check my sanity since the documentation I have been reading is confusing.
I have a TK790 VHF HP and a 890 UHF in a dual brick setup with a KCH11 head. The 890 UHF seems to be dead and no power, so I swapped the bricks and threw on the KRK-7DB TIB, and the setup is powering up no problem but I cannot read/write now with 44D. Is there also a resistor change that is needed internally on my donor brick which used to be a 890 w/ KRK-5? Or am I just missing something else in this conversion project?
ramal121
Lots and lots of watts
Calif Whine Country
Serial numbers above 011XXXXX did not require any internal modifications or jumpers to be set.
Did you change model type info to reflect radio 1 and radio 2?
nikronzo
4.X SloppyCast
Serial on the new 890 is 902XXXX so then we should be good there.
I plugged the new 890 right in after I slapped the KRK-7DB in, when I try and talk to the setup via 44D it says comm error. Should I program this 890 beforehand before plugging it in. Apologies for these basic questions, this is outside my usual radio experience.
