LACMTA Security
kearthfan101
Does anyone monitor or have insight on the LA Metro security frequencies? I'm seeing several frequencies broadcasting same info, some frequencies tied together, multi-selecting/only hearing one side of conversation, etc. Just wondered if anyone had more info on how the system is set up so I can monitor more efficiently. Thanks in advance.
ElevatorsAndRadios
yarewesog
SoCal
The channels are region-specific, and officers in the field manually select the channel. There is no automated subscriber voting. As I understand it, the SOC (Security Operations Center) transmits on all the channels at once, but you will only hear the units talking back to SOC if you are on the same channel as they are.
kearthfan101
Thanks! I'll see what I can do about figuring out which channel is which for each region.
LB_Scan
Hi @kearthfan101
Los Angeles County Metropolitan Transportation Authority (MTA)​
The Rail Operations NXDN channels use conventional voting and are simulcast. Scan all channels to determine the best one based on your location.
Los Angeles County Metropolitan Transportation Authority - 900Mhz
Motorola Type II Smartnet
Los Angeles County MTA Operations. Buses, Freeway Patrols, etc.
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
453.050WQDB916RM103.5 PLMTA SECFacilities-Security (phone-patch capable)FMSecurity
453.275KRW246RM136.5 PLMTA SECFacilities-SecurityFMSecurity
453.325KRW246RM136.5 PLMTA HQHQ Staff / ManagementFMTransportation
453.475KRW246RM136.5 PLMTA SEC UNDERFacilities-Security - UndergroundFMSecurity
453.625KRW246RM136.5 PLMTA SEC UNDERFacilities-Security - UndergroundFMSecurity
460.400WNXJ405RM173.8 PLMTA SECFacilities-SecurityFMSecurity
460.4125WNXJ405RM110.9 PLMTA SECFacilities-SecurityFMSecurity
460.425WNXJ405RM141.3 PLMTA SECFacilities-SecurityFMSecurity
43.780KMA454BM114.8 PLMTA FallbackBus / Facilities Maint Back UpFMTransportation
939.450WPXP659RM023 DPLFSP PATCH BFreeway Service Patrol (Patch TRS TG1584 Base only)FMTransportation
151.670WQME499RM060 RANMTA E OpsE Line (Expo) Rail OperationsNXDN48Transportation
151.850WQME499RM045 RANMTA DowntownDowntown LA Rail Operations (A (Blue) / E (Expo) Lines)NXDN48Transportation
152.915WQJZ495RM014 RANMTA K OpsK Line (Crenshaw) Rail OperationsNXDN48Transportation
153.815WQEV690M035 RANMTA E YardE Line (Expo) YardNXDN48Transportation
153.815WQEV690M055 RANMTA B/D YardB (Red) / D (Purple) Line Yard OperationsNXDN48Transportation
154.025WQAC619M055 RANMTA Events TacSpecial Events TacNXDN48Transportation
155.805WPXM799M055 RANMTA L YardL Line (Gold) Yard OperationsNXDN48Transportation
155.850WQFX628M055 RANMTA C YardC Line (Green) Yard OperationsNXDN48Transportation
160.3875WQMR978RM020 RANMTA B/D OpsB (Red) / D (Purple) Line Rail OperationsNXDN48Transportation
160.470WQMR978RM020 RANMTA B/D OpsB (Red) / D (Purple) Line Rail OperationsNXDN48Transportation
160.5825WQMR978RM005 RANMTA B/D Tac UGB (Red) / D (Purple) Line Emergency Tac UndergroundNXDN48Transportation
160.5825WQMR978RM050 RANMTA A OpsA Line (Blue) Rail OperationsNXDN48Transportation
160.695WQMR978RM020 RANMTA B/D Ops UGB (Red) / D (Purple) Line Rail Operations UndergroundNXDN48Transportation
160.7625WQMR978RM006 RANMTA L North OpsL Line (Gold) Rail Operations (Pasadena-Azusa) FoothillNXDN48Transportation
160.785WQGH863M055 RANMTA A YardA Line (Blue) YardNXDN48Transportation
160.8675WQMR978RM020 RANMTA B/D OpsB (Red) / D (Purple) Line Rail OperationsNXDN48Transportation
161.0325WQMR978RM060 RANMTA E OpsE Line (Expo) Rail OperationsNXDN48Transportation
161.1225WQMR978RM020 RANMTA B/D Ops UGB (Red) / D (Purple) Line Rail Operations UndergroundNXDN48Transportation
161.1225WQMR978RM030 RANMTA C OpsC Line (Green) Rail OperationsNXDN48Transportation
161.1675WQMR978RM020 RANMTA B/D OpsB (Red) / D (Purple) Line Rail OperationsNXDN48Transportation
161.2425WQMR978RM015 RANMTA B/D Tac 2 UGB (Red) / D (Purple) Line Emergency Tac 2 UndergroundNXDN48Transportation
161.2425WQMR978RM020 RANMTA B/D OpsB (Red) / D (Purple) Line Rail OperationsNXDN48Transportation
161.265WQMR978RM040 RANMTA L South OpsL Line (Gold) Rail Operations (East LA-Pasadena)NXDN48Transportation
161.4675WQMR978RM015 RANMTA B/D Tac 2 UGB (Red) / D (Purple) Line Emergency Tac 2 UndergroundNXDN48Transportation
161.4675WQMR978RM040 RANMTA L South OpsL Line (Gold) Rail Operations (East LA-Pasadena)NXDN48Transportation
161.4825WQMR978RM005 RANMTA B/D Tac UGB (Red) / D (Purple) Line Emergency Tac UndergroundNXDN48Transportation
161.4825WQMR978RM030 RANMTA C OpsC Line (Green) Rail OperationsNXDN48Transportation
161.505WQMR978RM020 RANMTA B/D OpsB (Red) / D (Purple) Line Rail OperationsNXDN48Transportation
161.565WQMR978RM050 RANMTA A OpsA Line (Blue) Rail OperationsNXDN48Transportation
160.425WQMR978RM010 RANMTA MaintenanceRail Facilities MaintenanceNXDN48Transportation
160.4925WQMR978RM010 RANMTA MaintenanceRail Facilities Maintenance UndergroundNXDN48Transportation
160.8525WQMR978RM010 RANMTA MaintenanceRail Facilities MaintenanceNXDN48Transportation
160.8825WQMR978RM010 RANMTA MaintenanceRail Facilities MaintenanceNXDN48Transportation
161.145WQMR978RM010 RANMTA MaintenanceRail Facilities Maintenance UndergroundNXDN48Transportation
161.3475WQMR978RM010 RANMTA MaintenanceRail Facilities MaintenanceNXDN48Transportation
161.5275WQMR978RM010 RANMTA MaintenanceRail Facilities MaintenanceNXDN48Transportation
kearthfan101
@LB_Scan thanks, I’m pretty aware of that considering I was responsible for submitting about 90% of that info to the database. My question was concerning the separate UHF conventional frequencies for security, which ElevatorsandRadios was helpful in responding to.
LAflyer
Global DB Admin
Moderator
SoCal
Don't know how current or accurate the info is, but according to web search, MTA divides its operations into five or six regional zones.
One listing I found has six:
Central / Union Station
San Fernando Valley
San Gabriel Valley
South Bay
Westside
Gateway Cities
Other had 5:
Gateway Cities (Southeastern LA County)
San Fernando Valley
San Gabriel Valley
South Bay
Westside/Central
Suppose the frequency usage could be along these lines.
LB_Scan
hi
Frequency (MHz)6-Zone Assignment5-Zone Assignment
453.0500Central / Union StationWestside/Central
453.2750San Fernando ValleySan Fernando Valley
453.4750San Gabriel ValleySan Gabriel Valley
453.6250WestsideWestside/Central
460.4000South BaySouth Bay
460.4125Gateway CitiesGateway Cities
460.4250Systemwide / Events / OverflowSystemwide / Events / Overflow
