LAFD Lowband
Squelchtail
As a Lowband guy living in the past. I became interested in the LAFD Lowband system. I did some looking around the following.
KMA706
33.70 F1 Fire Control
33.82 F2 Tac 1 Valley Division
33.90 F3 Tac 2
33.94 F4 Tac 3 Brush
33.60 F5 Command
33.48 F6 Service
33.86 F7 Mutual Aid
35.58 1947?
38.70 1946?
Anyone have any good history on this system you would like to add?
prcguy
KMA706
33.90 F3 Tac 2
33.60 F5 Command
33.48 F6 Service
33.86 F7 Mutual Aid
35.58 1947?
38.70 1946?
As a kid starting around 5yrs old I got to climb through the on air racks at the LAFD signal office in San Pedro when my father was stationed there on and off. I think they did south dispatch out of there and it had a lot of racks of radio stuff so the signal office probably did more. During the 60s I would play with the radios in the fire trucks and occasionally hear skip with the PL turned off. I remember 33.7 and 33.9 being most active in the south area.
I also remember them getting VHF low band HTs made by KAAR and those had a pull out telescoping antenna. Those didn't seem to be around very long and that might have been just before migrating to 500MHz and I got to see the radio techs change out some of the engines with the new radios and antennas with mounts and ground plane mounted up high.
vavolff
No Tac Channel Assigned .....
Virginia Beach, VA
Check this out this link, it's a historical timeline of significant LAD radio events, might be helpful or you. I was they went into detail, but this works too. Lemme know if this helps/doesn't help. There used to be a webpage that dove into detail on LAPD's radio history. I think it mentions some LAD history as well. I'll dig around and try to find it. Like you, I love diving into something's history and more context.
prcguy
Nice link, haven't seen that one before. I see a question about the Digicom status buttons being on VHF lo band.
?1972? - "Digicom" status buttons were added in apparatus (?on low band?)
I remember playing with the radios and the Digicom push buttons came about after the 500MHz radios were installed, I don't remember them on the older VHF lo band radios and I never saw a VHF lo band radio after the 1972 UHF upgrade. I also remember asking the Captain at station 101 in San Pedro what the buttons were for and he explained it all to me then as a teenager very interested in radios. My father was an LAFD fireman from about 1947 through 1976.
Squelchtail
Thanks that’s some good info
Engine104
Member since 2005
Winnetka, CA
I remember the old LAFD low band system. In the fall, you could hear a rural Ohio FD's dispatches on 33.82 Mhz.
I am certain, though, the Digicom signals predate the UHF system. I remember hearing that way back in the early 1970s when all I had was a low band tunable receiver from Lafayette.
jland138
San Francisco Bay Area
There's a message about Digicom in the preface of the 1976 Southern California edition of Police Call:
The word "Digicommed" has been added to the jargon of radio users and listeners. Digicom is the digital signaling system installed by the LAFD as part of its computerized dispatch system. When a status button on a fire unit is selected, Digicom sends out a unique set of beeps. Registered at the computer, the base station retransmits this code back to the unit, usually within microseconds. A "sniffer" in the mobile is supposed to prevent retransmission until the frequency is clear. However, mobiles frequently cannot receive another distant mobile and transmit the when the frequency is in use. The base reply thus overrides field traffic, so that a cut-off unit has been "Digicommed." System works fine in a repeater system, but somebody goofed on this one.
The 1984 Southern California edition contains the annotated list of 500 MHz frequences and lists 33.90, 33.48 and 33.86 as Digicom channels.
This forum had a nice thread on LAFD radio history in July, 2021 which contains a lot more information.
ladn
Digicom was active on the low band system. It would sometimes blast out override voice transmissions. Firefighters called that being "Digicommed". Really annoying to listen to on my Regency TMR 8XL scanner at the time.
Squelchtail
What was the digicom system.
See the big beautiful whips. Even the chief has a portable radio.
Came across this LAFD info from the Fm-Tv magazine dated June 1 1949
2 Base stations 33.90 Mhz
2228 W. 6th St. call sign KCJD
14415 Sylvan St.
210 Mobiles, KCJE
1624 Purdue Ave. KCUG
524 N. Spring St.
#LAFDFFLife
The impact of technology on our lives, especially over the last decade, is profound.
Just one of the many examples of the changes technology has brought to #YourLAFD is the way our resources communicate location back to our dispatch center.
The white box on the left is "Digicom". Addresses were written down by hand (from the radio dispatch) and the officer on the fire engine/truck would punch the appropriate button the on the Digicom to indicate their status.
The most important buttons are across the top:
ENR = Enroute to the call
ONS = Onscene at the call
AVI = Available from the call (released/done)
RAD = Available via the radio (meaning you're in the engine/truck)
QTR = Once you return to the station, shows you are available
'In Quarters"
CAV = Conditionally available - example: involved in a training drill
and if you're sent on a call, you'll be delayed
LOC = Used with "RAD" you enter the number of the fire station
district you are "available by radio" and then hit this
example: '13' 'LOC' = fire station 13's district
Now, bring in the Information Technology Revolution! Today, in every LAFD apparatus you will find the computer on the right, 'Mobile Dispatch Computer' (MDC)
The dispatch information will appear on the computer screen providing all the key information for a response. And if you look closely, you'll see buttons that pretty closely resemble the Digicom.
We could provide much more detail....but we don't want to bore you! If you're really interested, we invite you to stop by any LAFD fire station and take a look!
prcguy
#LAFDFFLife
'In Quarters"
When the 500MHz radios went in around 1972 I remember being shown something that looks like this for the Digicom. They had a new Micor style control head instead of the older Mocom with a matching push button add on made by Motorola.
Squelchtail
#LAFDFFLife
'In Quarters"
Thanks that’s interesting..
Squelchtail
#LAFDFFLife
'In Quarters"
Thanks that’s interesting….
mikegilbert
MHz so good
Los Angeles
I've got a black status / message panel on my Syntor "SuperStack" radio.
MiCon
Mike
central AZ
I deleted the LAFD low band frequencies from my list eons ago, so I'm going by memory. I used to drive from Riverside, CA to Phoenix, AZ to visit family. It seemed that around Desert Center, CA I could always pick up LAFD disp on 33.7. Don't know if there was a window to that area or not, but it was pretty constant. Depending on where the transmitter was, that's a distance of about 150 miles.
Squelchtail
14415 Sylvan St.
210 Mobiles, KCJE
524 N. Spring St.
I looked at the 2228 W. 6th location on google earth ant shows the lowband antenna still on the tower.
ladn
"What was the digicom system."
The Digicom System was a digital signaling and mobile data system the LAFD used to communicate between apparatus and the dispatch center(s). It was introduced, as I recall, in the '70's. This was in the time before mobile data terminals. An engine crew or rescue ambulance would simply push the appropriate button to update their status such as "enroute", "on scene" "transporting" and "available".
The system used a series of tones to encode the data transmissions and it was a dumb system in that it did not have a "channel busy inhabit" feature and the Digicom updates would sometimes step on voice traffic, leading to a new term, "digicommed", being added to the firefighters' lexicon.
Since the 33 MHz system of the time used carrier squelch, there wasn't any way to avoid hearing the incessant beeps.
prcguy
This prompted me to look at the LAFD signal office in San Pedro that was diagonally across the street from fire station 53 which closed down many years ago. The satellite view on Google Earth still shows the signal office building and property and last time I drove by a couple of years ago the tower and low band antennas were still there with other antennas. But the street view on Google earth shows the signal office building and tower has been removed and the fire station is still intact and being used for something else. This is at the intersection of Oliver and Mesa streets in San Pedro, CA.
