Laird NMO mag-mount
nokones
Sun City West, AZ
how do you like that magnetic HMO mount? I'm thinking of buying a cheap one to try the Larsen nmo 34 and 64 inch antenna to make sure it performs well before I drill a hole.
I have found that the Midland MXTA12 Mag Mounts are the best for good VSWRs on GMRS freqs. Midland really has improved the quality of their Magmounts in the last couple years. I have had better results with the Midlands over the Lairds.
Ensnared
Waco, Texas
I just bought a 2008 Colorado. I have been using this base for a Larsen Tri-band. If you want to protect your paint from scratching, this worked great for me.
Based on the year model of the pickup, I am giving up & giving in to the many suggestions of others. I am going to have Troy's Two Way drill the hole for a NMO CB antenna.
I am going to keep the tri-band scanner setup for long trips. Typically, I use a rubber duck in the vehicle to hear radio transmissions. I don't like to hear LE discussing why I have a scanner. Both antennas seem to attract unwanted attraction from LE.
5 1/2" (135lb Strength) NMO Magnetic Antenna Mount 17ft RG58 BNC Male Connector
If you buy one, I always buy the one with 58/U, not 58AU. I cannot even solder a 1/4 guitar cord. So, I use a twist-on BNC connector.
