Las Conchas Wildfire
abqscan
DataBase Administrator
Moderator
AOA
NM Fire Info
Follow Santa Fe NF @SantafeNF
Jemez Mountain Fire as seen from Rio Rancho | Flickr - Photo Sharing!
Frequencies heard so far (hope people are upgrading to digital scanners!!!)
120.500 Las Conchas North Zone Air Control
121.025
122.925
123.125
162.965 PL 167.9 NIFC CMD 7 Repeater using 171.7875 input
163.025 Air Ops Air-To-Ground
164.965 PL 103.5
167.135 PL 206.5 USFS - FTC Incident Repeater
168.35 PL 203.5 (Common)
168.625 PL 110.9 Air Guard
168.65 PL 110.9 Nat Flight Following
169.15 Air-to-Ground
169.2 Air-Attack
170.05 $111/ PL 151.4 (P25 & Analog) Bandelier National Monument
170.525 PL 110.9/131.8
171.45 PL 131.8 Cibola National Forest
171.575 Tanker Base
172.3 PL 127.3 Santa Fe National Forest
172.675 PL 114.8, Southern Pueblos BIA
I am also seeing 3 MAFFS C-130's up on my radar.
This aircraft is overhead as a spotter plane.
N513BT | Flickr - Photo Sharing!
m0unds
albuquerque, nm
NM Fire Info
168.625 110.9 Air Guard
168.65 110.9 Nat Flight Following
169.2 Air-Attack
170.05 $111 Ground Cordination
170.525 110.9/131.8
171.45 131.8
172.3 127.3
thanks for the info.
i'm a swing shift surveillance engineer for one of the pueblos, and we can see the easternmost part of the fireline via IR with our outdoor cameras. it's not burning as bright as it was, likely partially obfuscated by the smoke.
ecps92
Taxachusetts
Please take a look at the RR Wiki and add/edit as needed.
I noticed some of the Freq's listed below, might be Mutual Aid from Cibola NF?
Any idea who the P25 user is ?
NM Fire Info
169.2 Air-Attack
170.525 110.9/131.8
171.45 131.8
172.3 127.3
abqscan
Moderator
AOA
The P25 stuff almos sounds like park rangers. They are cordinating evac areas and road blocks. There are also analog transmissions on the same freq which seems weird to me.
ecps92
Taxachusetts
Simplex or a Repeater? Could be a common Mutual Aid channel... rather odd NPS NAC, as they tend to stay around $4F# series NACs.
Good Find.
abqscan
Moderator
AOA
I had it looged in the past as $411, however when the fire took off, I started hearing the $111 nac code. and then some analog stuff as well. I can't tell if it is a repeater, I searched for an input but didn't find any and I most transmissions were motor-boating due to a weak signal. It might have been simplex.
Mjvaldez69
172.3000 and 168.1250
Most of the information I am getting is from these to frequencies!
30 structures already lost toward Cochiti! Dixon apple orchard in the fireline!
nmbobcat
Rio Rancho, NM
170.05 is a Bandelier National Monument (NPS) repeater on Dome. I've noted that it is mixed analog and digital since the day they did the conversion a couple years ago.
171.45 used to be the main Cibola National Forest frequency, and although not listed in the RR database is still heavily used. You'll hear the Capilla Peak lookout on this frequency.
Dave
Fowler
FL
Any National Guard freqs?
Fowler
abqscan
Moderator
AOA
I read that Peterson AFB was sending 2 C-130's and their A/A freq is 376.025.
ecps92
Taxachusetts
Any tone for Cibola?
Dave
abqscan
Moderator
AOA
I have a PL of 131.8 on 171.45. I also came across 162.965 - 167.9PL and 167.135 - 206.5 PL last night.
ecps92
Taxachusetts
-k sounds like Cibola
162.9625 is NIFC CMD 7 Repeater using 171.7875 input
167.1375R / 173.6250 is the USFS - FTC Incident Repeater
skyhawk133
Albuquerque, NM
167.975 Possibly FEMA Ops
163.025 Air Ops Air-To-Ground (confirmed)
170.685 PL136.5 Forest Service??
166.610 PL136.5 Forest Service??
162.960 PL167.9 Type 1 Team Ops?
beerzkool
Scanning the Pajarito Plateau since 1995.
Los Alamos, New Mexico
Dave
You might hear rangers on 164.425 and it is definitely digital.
skyhawk133
Albuquerque, NM
119.450 Pacheco Fire Victor Air
172.3 PL162.2 Pacheco Fire Command (Lots of Air coordination, etc.)
abqscan
Moderator
AOA
add 172.675 PL 114.8, Southern Pueblos BIA.
