The 120 volt AC powered LED might use a switching power supply inside the base and the 24 volt might use a buck converter. Either of these can make RFI. Guess it really depends on how it was made and would likely vary from manufactures.Assuming lumens/brightness are equal, does a 120V ac-powered LED lightbulb emit more, less or equal RF than a 12 or 24V dc-powered LED? The same frequency or different?
But somewhere there must be an AC to DC converter that may be a radiating power supply unless you're powering with batteries. Then how do you charge them? Its hard to get away from these spectrum killers!A LED powered direct from DC should not make any RFI.
Thank you for the expanded explanation as my question was lacking. I’m thinking about moving my shack to a detached garage. And, the possibility of using 12V or 24V dc for lighting,The 120 volt AC powered LED might use a switching power supply inside the base and the 24 volt might use a buck converter. Either of these can make RFI. Guess it really depends on how it was made and would likely vary from manufactures.
Use a true linear DC power supply. Stay away from SMPS types as that's where the noise comes from in the majority of cases.But somewhere there must be an AC to DC converter that may be a radiating power supply unless you're powering with batteries. Then how do you charge them? Its hard to get away from these spectrum killers!
Not necessarily. Keep in mind that an LED is a diode. Many of these lights have no rectifiers. They feed the 120 VAC to a string of LEDs in series (to drop the voltage) and may add a capacitor to take care of the ripple and maybe a resistor to knock down the voltage.But somewhere there must be an AC to DC converter...
Icom used to sell power supplies to accompany their HF radios. I have an Icom PS-125 that I use to power my IC-7610. No RF noise from the power supply. If you build a SMPS correctly, it will be quiet.Use a true linear DC power supply. Stay away from SMPS types as that's where the noise comes from in the majority of cases.
All very true.Icom used to sell power supplies to accompany their HF radios. I have an Icom PS-125 that I use to power my IC-7610. No RF noise from the power supply. If you build a SMPS correctly, it will be quiet.
Years ago I bought a string of warm white LED Christmas lights and hung it around the perimeter of my living room for ambient lighting. It had an annoying 30 cycle flicker, telling me it was half-wave AC. I cut off the end and inserted a full-wave rectifier, it looked pretty cool after that.Not necessarily. Keep in mind that an LED is a diode. Many of these lights have no rectifiers.
