Ledyard FD OPS 17206 Issues
THE54
I had this channel programmed in my Unication G5 pager, it worked and the tones worked on it too.
Ledyard FD OPS CLMRN 17206
A couple weeks ago the channel stopped coming across my pager. All other channels work.
I tried reprogramming it several times with no luck.
Looking to find out why it has randomly stopped. I even redownloaded it from radio reference and it still doesn't work.
THE54
The channel works on the pager if I upload one old file I have. The problem is when I try to make a new file it doesn’t work. The channel is active and fire department is currently using the channel. I feel like when I import the channel from radio reference it’s the wrong channel possibly.
nhfdcadet
CETsr
New Hartford, Ct
Without seeing it myself, I couldn't even tell you where to begin looking. There are a ton of things that could be set incorrectly, and one little thing being wrong can make the whole thing not work.
So this just randomly stopped working one day and then you reprogrammed it and it still didn't work but then reverting back to the original programming that stopped working, it started working again?
THE54
I turned off the binding feature and it resolved the issue. Not sure why. Also creates an issue because I believe I’ll need the binding feature turned on for the pager to activate via tones. Maybe I can shorten the binding feature times and that will fix the issue?
nhfdcadet
CETsr
New Hartford, Ct
enable alternatives on your sub group
