Off topic warning: I'm surprised we haven't seen a crowd source distributed smart phone app for reporting speed traps with GPS precision.
Doesn't Trapster do this?
of interstate or foreign communications. Unless you are listening to communications across state lines or from foreign countries, it doesn't apply.
Mike
RadioReference still stands by it's position.
Please note that the K&L Gates letter and opinion has nothing to do with this issue - that related to the MRA issue with publishing LTR talkgroups and LCNs.
However, some further position information. In addition to beginning of 47 USC 605:
Except as authorized by chapter 119, Title 18, no person receiving, assisting in receiving, transmitting, or assisting in transmitting, any interstate or foreign communication by wire or radio shall divulge or publish the existence, contents, substance, purport, effect, or meaning thereof, except through authorized channels of transmission or reception,
the law also includes the following exemption:
This section shall not apply to the receiving, divulging, publishing, or utilizing the contents of any radio communication which is transmitted by any station for the use of the general public, which relates to ships, aircraft, vehicles, or persons in distress, or which is transmitted by an amateur radio station operator or by a citizens band radio operator.
My emphasis added.
47 USC 605 does not explicitly define the definition of "for the use of the general public," however the law referenced (Chapter 119, Title 18 § 2510) does explicitly define it as:
(16) "readily accessible to the general public" means, with respect to a radio communication, that such communication is not--
(A) scrambled or encrypted;
(B) transmitted using modulation techniques whose essential parameters have been withheld from the public with the intention of preserving the privacy of such communication;
(C) carried on a subcarrier or other signal subsidiary to a radio transmission;
(D) transmitted over a communication system provided by a common carrier, unless the communication is a tone only paging system communication; or
(E) transmitted on frequencies allocated under part 25, subpart D, E, or F of part 74, or part 94 of the Rules of the Federal Communications Commission, unless, in the case of a communication transmitted on a frequency allocated under part 74 that is not exclusively allocated to broadcast auxiliary services, the communication is a two-way voice communication by radio;
For purposes that involve us, Chapter 119, Title 18 § 2510 defines Part 90 FCC licenses (most public safety FCC licenses) as for the use of the general public. 47 USC 605 exempts those stations.
Furthermore, one could argue that public safety communications relate to "persons in distress" which are also exempted by 47 USC 605.
I'll play devil's advocate, and point out that:
1. 47 USC 605 generally prohibits divulging or publishing contents of received communications.
2. 47 USC 605 has an exception for "as authorized by chapter 119, Title 18".
3. Lindsay's quoted Chapter 119, Title 18, § 2511 says nothing about divulging or publishing - it only refers to interception.
What we really need is something in Chapter 119, Title 18 that specifies some authorization to divulge or publish.
(EDIT: my (1) and (2) above only refer to the part of 47 USC 605 quoted by Lindsay above, not to the entire chapter.)
What the difference. Most all police retransmit the coms on the i-net all the time. Dispatch> I-net> Tower> to the police officers. Its called voice over ip. Hams do it all the time. Its all legal. The "WEB" is cast all over the world. Once any data is sent to the web, it transmitted all over the world. So if rebroadcasting was illegal. Then all Police, Fire, EMS, Local & Federal Government would all be charged with a crime.
I have had to take down one of my feeds - Newport News Fire Department , Newport News, VA.
Not quite. Dispatch > Private Network (microwave or leased carrier T1 line) > Tower > field units. Even with IP technologies, there are no public internet links involved.
