zero_frequency
I'm in the process of mounting a SPGP on the exterior wall of my home where I will run the "protected" side cables into my shack. It's really the only place I can mount it.
My question is, when running braided cable from the ground bar to the SPGP (all interior), I would have to run this cable across two walls via a corner, so there would be a distance of no more than 20', max. I'm wondering if this is too far from my rig to the panel where I would then drop straight down with a flat cable attached to a ground rod. Would this be considered excessive or not a problem?
Any thoughts much appreciated.
