BOBRR
Hello,
Took the plunge, and purchased a WinRadio Excalibur SDR receiver.
I would like to protect it as best I can.
I do receiving only (<30 MHz), and have an end-fed antenna from PAR outside.
We get a fair amount of lightning in the area, but have never had any direct hits.
I have the typical ICE lighning arrester at the junction (outside) where the antenna joins the coax leading to my radio in a room upstairs.
The arrester is connected to a ground rod that I banged into the soil.
What concerns me most I think is the voltage being induced, possibly, by nearby strikes.
If anything actually hits the arrester, I doubt that it, or anything, would survive.
Probably more of a "feel-good" kinda thing than anything.
So, let me ask please.
a. Can "nearby" strikes, say 1/8 or 1/4 mile away actually induce meaningful voltages in the antenna (about 10 feet above the ground, running horizontally) ? How large ?
b. I try, but I am not always home, or remember always to do so frankly, to disconnect the antenna when done using the radio. "Old-Age" problem, apparently.
What kind of "protector" can I put right at the radio to try to protect against any
voltage surges (not direct hits) ?
c. What about voltage surges coming in via the AC line ?
d. What about static (buildup) charge ?
Are most modern radio front-ends, like hopefully on the Excalibur, reasonably protected against static buildup and "low" voltages ?
e. I've read about the Polyphaser line of gadgets. Is one of these what I possibly want for directly at the radio input in the house ? They sure are pricey.
It, or anything used here, would only have as a ground a wire strapped to a forced hot water heating pipe (which is also electrically connected to the house water supply)
I've also read about using neons back to back, and 10 meg ohn resistors, etc.
Seems to be a lost of cons to this approach, as well as possible benefits. Thoughts on ?
Any thoughts on all of this would be most appreciated.
Thanks,
Bob
Thanks,
Bob
