Distance between them? Expected or actual coverages? (Are their coverage areas overlapping? A little/A lot?)
Analog only? Or Analog & Digital, switchable?
Simplest analog version would be something like 4 wire with an E&M signalling pair; 6 wire, using the wildcard programming. Assuming you have the correct Wireline card that has all of those functions.
But then how to accomplish that given your distances? I've linked a VHF & a UHF quantars in a cross-band configuration this way, but they were literally side by side in the room. Easy peasey, as the little lizard says.
Any real distance will need to involve either leased Telco lines ($$ to set up thru your telcos, and then recurring monthly rape, errr, rate charges, depending on whether it's one circuit on copper, or thru a T1 link, which probably only makes sense if you have other circuits you need to transport. Or as buddrousa says, a microwave link; assuming Line Of Sight between you.
Running digital? Def. need a IP network connection.
We're better than Radio Shack: You've got questions? We got non- stupid answers, but we might be kinda sarcastic sometimes.
