I would like to share an odd discovery. I have wireless weather stations by Oregon Scientific and Hama operating at 433.92 MHz, which have had problems with synchronization with the outside temperature transmitter. I finally realized that the problem could have been caused by RFI and tuned my venerable Baofeng and IC-R2 to the above mentioned frequency to find that there was a heavy noise present within ca. 5 to 7 yd. from the operational SPA921 phone. When the mains power supply plug was disconnected from the phone, the noise disappeared in the same moment. When the VOIP phone was unplugged and off, the weather station received the data from the wireless outside temperature probe without hassle. Note the power supply for the above mentioned phone does not produce RFI when plugged in to the mains.
I have two such old phones at two different locations, which were purchased a long time ago from different outlets. They have different firmware and mfg. dates, and surprisingly they have a large sticker claiming that they were FCC rules compliant, which have been know to be very stringent. While these phones are no longer supported my the manufacturer, I would like to ask if someone also has such a device and a radio scanner and could kindly tune to 433.92 MHz to check if any noise is present in vicinity of an operating VOIP phone of the SPA series?
