Listening on raspberry pi
tgrantjr
I am a new premium member. I have a rip 3b+ that I am working on using headless to just play feed 236 and send it to a Bluetooth speaker. I have the speaker setup and working. I have mpv and VLC installed for this mode. Every time I try to start the feed it errors out on me that it can’t connect. Has anyone else tried this and have it work or am I just out of luck? Thanks
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
To resolve your connection issue, you need to ensure you are passing your Broadcastify credentials along with the stream URL. When using command-line players like `mpv` or `vlc` (via `cvlc`), you can typically include your username and password directly in the URL string or via specific flags.
tgrantjr
I want to use mpv. Do you happen to have somewhere I can get the string and input my credentials?
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Code:
https://tgrantjr:{your_password}@audio.broadcastify.com/236.mp3
Note: do not use this functionality to scrape or programmatically download feeds for AI, transcriptions, LLMs, your own Claude created incident notification network etc - that is considered commercial use of our products and service and you'll get blocked. If you are reading this, and that's what you want to do, get started at Broadcastify - Integration and Developer Portal
mshadwick
SharkMadwick (K5MCS)
Heavener, OK
Code:
Has anyone attempted this or something similar on a Grace Digital Mondo Elite online audio player?? I was using the
https://broadcastify.cdnstream1.com/ server till it was no longer available.
mshadwick
Heavener, OK
Sorry this was off topic, but just an update to this. The Grace Device will not play even if the credentials are included in the new URL's.
