Little antenna help
Claudiofish4
CANADA
I could use some help please. I have a uniden bcd996p2 with a hustler mag mount. I also jave the uniden 880 bearcat. Where would be the best place to put the two antennas on the car. I know they cant be side by side but what would work best.
Claudiofish4
CANADA
Does it matter where on the roof for the scanner and can i also put CB up on the roof. What distance should they have between each othwr .
buddrousa
I would want the CB antenna as far away from the scanner antenna as possible. I would not even consider any type linear amp on the CB you would be asking for trouble with new modern scanners.
