Little help with Jersey Central Power & Light
JimBobTerp
Easton,PA
Hi
I live in the Northampton County in Easton,PA. I was able to hear this system all fine for while and now I can not hear any active when it stops on any of the frequencies or talk groups. I was told I need to put just the Control channels and that is how I heard the active before. Can someone help me here with the North Branch please. FELHC (Jersey Central Power & Light) Trunking System, Various, New Jersey - Scanner Frequencies I put the two RED ones in and no active anymore. I am going to try and work on this and other things while we have this snow day like today. Thanks so very much.
Skypilot007
Medford, NJ
I would try setting the scanner to each of the control channels to see if you can hear any of them. If not you may have an antenna/feed line issue, or the system has had some changes to it. 900MHz is tough to hear sometimes. It requires a good antennna and feed line unless you are right next to the site.
