w6act
Thanks for the tip. One more question, I read that the low noise amplifier should be mounted as close to the antenna as possible. Is that true?
Alex
Alex
A receiver with internal noise of 6dB will add that noise to the signal and at lower signal levels it will begin to be more noise than signal. Amplifying the signal to let it be 6dB stronger will raise the weak signal above the noise level and the 6dB noise in the receiver will then have much less impact on the systems total noise figure.Additionally, the impedance graph posted is misleading, because the input impedance by frequency changes depending on what specific frequency is tuned and which band filter is active.
To add to the discussion.... I’ve got 75’ of LMR-400 on the way but I can’t find anywhere where it says what the impedance of the cable is. One of my antennas is a folded dipole with a 300 to 75 ohm transformer. Can I use this regardless of the cable?
Standard LMR-400 is 50Ω cable.
Yes, there will be a slight mismatch in impedance, but for scanner use, that will not be noticeable.
They do make an LMR-400-75, that is 75Ω, but don't change your order, you won't have a problem with standard LMR-400.
LMR®-75 Ohm - Times Microwave
www.timesmicrowave.com
Thanks, I didn’t even think of this being an issue before ordering. I can always get a 50 ohm transformer so it all matches up.
Most of those 75-300 transformers accept an "F" connector, typically used for TV antenna and cable signals, and I don't believe that F connectors for LMR400 cable are common. If this is your situation, you'll need an adapter between the LMR400 connector and the F connector of the transformer.One of my antennas is a folded dipole with a 300 to 75 ohm transformer. Can I use this regardless of the cable?
The impedance isn't that important but the length of the run can be. Which of the two has the least loss for the band(s) you'll be using? Then decide if that amount is loss is worth the cost. I doubt if there will be that much difference anyway.Hello everyone,
I have both LMR 400 and triple shielded RG6 coax for my Comet discone base antenna. I have a Uniden SDS100 scanner and would like to use the triple shielded RG6 because lots of folks say it's better then the LMR400. The RG6 is 75ohm and is better for receive only devices. I would like some opinions on this by some of you folks on this matter.
Thanks Alex
