I was curious about how airports might use location information. I thought LAX might be a good choice. I saw this:
RadioReference.com - Scanner Frequencies and Radio Frequency Reference Database
It is a little combersome to pick out the location information, so I'll ask what systems do not have location information?
As an aviation enthusiast, I have programmed many airport frequencies into my radio. I typically divide an airport into two systems, one for the aviation band and the other for the land radios (e.g. airport ops, security, cargo ops, etc...). Anyway, within the aviation band, I program three groups:
Field - tower, ground, clearance, emergency,
ARINC - (I know these have a new owner) these are air to ground aviation operations frequencies
Approach - approach / departure frequencies for this airport.
So within those three general groups, I think there is a valid discussion of what range to apply for a location based scanner... Even though you can hear airplanes for many miles when they are up in the air, I think it is reasonable to apply smaller radii.
Before I muddy the water more, a couple of questions...
1. What other systems don't support location?
2. Should we consider adding location to airports?
3. What are reasonable ranges for the different frequencies?
