brumey
CFO (Chief Fix-It Officer)
Hello:
A question for the Uniden experts. I have a SDS-100, HP1 and 536. I recently created and downloaded favorites and at some point, all three radio's went deaf to more distant systems. After some investigation, I found the range set to 0.0. Then I remembered I set Lat/Lon instead of Zip. I read the manual on the topic of location and the circles and have a few questions.
1) I assume by setting Lat/Lon, I went from a zip code 10 miles circle to 0. This then prevented me hearing systems that were distant (40+ miles). Does this seem like a reasonable conclusion?
2) I live on a hill, with clear line of sight to many distant systems. If I use ZIP code and it casts a 10 mile range, will it really prevent me receiving systems that I know I can here from 80+ miles away? If so, how do you get around this, change the ZIP to something close to the target listening systems?
3) Ideally, I'd like to use Lat/Lon but change the range between 10/50/100 miles.
4) I heard they I could change the properties of the system that comes from RR DB and make it cast a larger footprint. If I have to do that to hear it, will it not get written over with each DB update?
Educate me please
73's
Educate me please
73's
