Lock out CTCSS/DPL
BruceMichaels
Not "Some People"
Flying Over You
Is there a way that you can lock out a specific CTCSS/DPL on a frequency? There is an agency near me that uses a 2nd tone for different ops and I don't want to keep hearing the main dispatch channel, just the ops.
mule1075
Washington Pennsylvania
Yes it is hold on the channel and press enter. Edit current channel and press enter. Scroll down to set audio type select analog only and then select set lockout.
hiegtx
Dallas, TX
Be sure to mirror that change in Sentinel by either reading the scanner into Sentinel, or editing the Favorites list that the frequency is in. To modify in Sentinel, open the Favorites editor, selecting the list to change.
In the editor, open the system & department the frequency is in.
Click on the "Audio Option" for the frequency. In the poop-up menu, where you'd choose analog or digital, and set a PL or DCS code, click the check box under the PL/DCS setting drop down to lock out the specific one you want to lock out,
