ARC536: Log screen cut short.
JamesBrox
Santa Rosa County, FL
Running Discovery on a 536 with ARC536PRO. I can't see the all the info logged displayed right on my moniter . It's using only about 2/3s of the available space. Stupid, I know but can anyone help. Thanks. James
tvengr
Well Known Member
Baltimore County, MD
Try this. It works on similar problems with Whistler software.
Right click on the shortcut and select Properties > Compatibility > and under settings check the box for Override high DPI scaling behavior, then select System in the drop down box and hit Apply.
JamesBrox
Thank you for your reply. No luck though. Bummer
James
u2brent
OAMPT
KRWDPAXKRS1
You can adjust the column size by using your mouse. Same as just about any program in existence.
Move the curser to the title of each column and drag to fit as desired. You can hide a column too..
u2brent
OAMPT
KRWDPAXKRS1
Hover over the border area between the columns on the row with the titles, the pointer should change to indicate you can drag that column to resize it.
