long-distance remote control of PCR1500 ?
digitaljim6
Stockton, CA
So how does one remotely control a PCR1500 over a dial-up phone line connection now that there is only a USB port? At least the 1000's serial port could be connected to a modem at a remote location and controlled via dial-up from a PC. There isn't any Internet access so an IP-based connection isn't available.
Anyone have a solution?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
There's now software that offers limited remote support for the 1500 called PCR Remote. See the PCR1000 Wiki page (also works on that rx) for the link. How 'limited' it is I don't know.
73s Mike
digitaljim6
Stockton, CA
PCRemote requires Internet access. This needs to work on a stand-alone dial-up modem connection. Thanks for the info, though.
MacombMonitor
Wouldn't you still be able to connect your dial-up modem to the computer's RS232 serial port, and the PCR-1500 to a USB port?
digitaljim6
Stockton, CA
There is no PC. The 1000 could be connected directly to a modem and that was all there was at the remote location. It would be nice not to have to dedicate a whole PC to the remote location.
MacombMonitor
Gotcha! I have a PCR-1500 and I'm not so sure there is not still a serial port function internally on the board. If you click on the USB icon on the Icom software, it shows:
Port Setting
IC-PCR1500 2101287 COM=4
It's grayed out, so you can't change anything. It leads me to believe that maybe it has a USB-to-Serial adapter integrated on the main board. Maybe if you could get your hands on a schematic you could tell.
MacombMonitor
How did you obtain audio?
