long press button programming in armada
lancewhalwy
We just purchased a few Viking VM800's. I am looking in the armada program for long press option for man down button for the KMC72 mic. Can someone tell me where to find this in the armada client?????????
RodStrong
West
Have you tried Global/General/Miscellaneous "Button Press and Hold Duration"?
I'm not sure that you can control the long press time on a specific type of mic. I think it's a global setting. Good luck.
lancewhalwy
You are correct. I found that setting BUT how do you apply it to the buttons? Even if i cannot apply to mic i would like to apply to the top panic button.
RodStrong
West
Go to Global/Lists/Accessories/
Then if the mic you are interested in is not listed in the column of accessories, you have to click on the "Add" button near the bottom, and then pick the accessory from a drop down list (in this case, the KMC-70/72). Once the mic is added, you can click on it and go the the button assignment for it, and then assign a function for the buttons that apply. Good luck.
