Can someone point me to a part number or source for the P7200 programming cable please? Google has been zero help.
TIA
TIA
TIA
I don't know anyone who has this cable or I would have contacted them. I just can't justify $125 to program a $30 radio either so I'll just slink away. Thanks for your ideal suggestion though.$125 is what they go for. Either get it or find someone that can lend one to you
You paid money for a proprietary public safety radio and now you're surprised that you have to pay a premium to get it to work. This is why you do research prior to just dumping money into a project. There are no aftermarket cables for Harris like there is Moto.
Thank you. Does this cable have a DB-25 connector and require a rib?You can also get an LPE-200 cable and break off the side tabs and that will work just fine.
No RIB needed, but it does have DB-25.Thank you. Does this cable have a DB-25 connector and require a rib?
So am I to assume the DB25 plugs direct into a computer? Geez, this must be ancient.No RIB needed, but it does have DB-25.
No such thing as a RIB in the Harris world. That's a Motorola thing
Thanks Tom, I figured there had to be some sort of intermediate box with that D-sub 25 pin plug. It just didn't seem logical to me that the LPE-200 would accept RS-232 direct from a computer.Older radios (pre-Harris) including the LPE200 did require the GE TQ3370 or TQ3310 programming interface. P7100/M7100 and later only needed the correct cable.
The TQ3310 was for programming personalities only (more like the Moto RIB) while the TQ3370 was for programming or flashing (more like the Moto SmartRIB).
So that cable probably won't work with the P7200. I wouldn't risk it.
NOPE, those are like the MRK. very different.You can also get an LPE-200 cable and break off the side tabs and that will work just fine.
I've programmed several LPE-200s with just the cable and I've programmed even more P7100s and P7200s with the same cable. I have never had any issue. I'm even using a serial to USB adaptor.Older radios (pre-Harris) including the LPE200 did require the GE TQ3370 or TQ3310 programming interface. P7100/M7100 and later only needed the correct cable.
That is incorrect. Even the MRK does not need anything but the cable. I've used the same cable on MRKs as I have to program the LPE-200s and P7100s and P7200s. Older GE Radios did require an additional "RIB", but not these ones.NOPE, those are like the MRK. very different.
