Looking for simplex freqs
jaspence
Michigan
Simplex
Try a Google search for ham simplex frequencies.
ScanMaine
Lewiston Maine
I did, but I cannot narrow them ddown. Im kinda slow. I want accurate and correct info thats why i come here
AK9R
Central Indiana
Amateur radio is not channelized like other radio services. Amateur radio operators are free to operate on any frequency within the limits of FCC rules.
However, to help manage the VHF/UHF spectrum, we have band plans, gentlemen's agreements, which specify where repeaters should be and where simplex operations should be. I'd suggest starting with the ARRL band plan. But, your area may be different. Check with the repeater frequency coordinator for your area to see what they recommend.
Broken records
The standard simplex calling freq for 2 meters is 146.52,
Around me, we also tend to use 146.535.
For many years, we also used 145.670, but that's become a digital calling channel now.
Either 146.520 or 146.535 should work out for you.
The calling channel on 440 is 446.000.
N8IAA
Fortunately, GA
Thta does tell me what I want to know. Thats all band plan.. Iwant to know about simplex freqs. 2 meter onhas less than 8 to 10 but this isnt it
W9BU answered your question about the frequencies. There are set areas in 2m/1 1/4m/70cm for working simplex.
What wasn't explained?
Larry
phask
zanesville
Can you repeat that in English?
This makes no sense at all - slow down and re-read your post - also pay attention to the answers you are getting.
Simplex USAGE varies by location. If there is no repeater pair using it - it can be used for simplex. I've seen repeater output used as simplex as well as input with different PL or without PL - this was by club owner's that knew what they were doing.
I've been licensed for several years and rather inactive - but that is how it was in my area.
" 2 meter onhas less than 8 to 10 but this isnt it"
ecps92
Taxachusetts
Hopefully Google can Translate your message.
Try #1
That does not tell me what I want to know. Thats all band plan.. I want to know about simplex freqs. 2 meter has less than 8 to 10 but this isnt it
Did you even READ ANY of the documents ??
IT DOES specificially list the Simplex Frequencies for
http://www.nesmc.org/docs/bandplans.pdf Read page 2, re-read and then read again
6 Meters aka 50 Mhz, 2 Meters aka 144 Mhz, 1.25 Meters aka 220 Mhz, 70 Centi-Meters aka 440 Mhz, 33 Centi-Meters aka 900 Mhz and 23 Centi-Meters aka 1.24 Ghz
your info about less than 8-10 frequencies is bad info
AK9R
Central Indiana
phask
zanesville
Obviously he did not read MY post either. ANY 2 meter freq. can , may . shall. be used as simplex, with 7minor exceptions.
ecps92
Taxachusetts
Some people ask and are handed the answers.
Others need to be spoon-fed the answers they want, not the correct info.
O well, it's nice n warm today [ inside :) ]
Looking at the OP's other posts - he either has an issue, or is just plain stupid.
Either learn to read and reply with some degree of competence - or shut up.
Agree - ignore him.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
SERIOUSLY??? The link to the band plans explains EXACTLY what the Simplex Frequencies are... Did you even look at them?
Attached is an image that CLEARLY shows what frequencies are available for simplex use.
AK9R
Central Indiana
Folks, I think the question has been answered. It's now up to the OP to act on the supplied information. As a result, there's probably no need to keep this thread open.
Also, this forum is not the place for insulting other members.
