jbergeron
Hello and thank you in advance for your time.
I have a Radio Shack Pro-197 Base Scanner with the standard telescoping antenna and it's worked fine for the past 3 years until a couple months ago. I am only trying to monitor 1 frequency (155.81250 NAC 293 for the Pelham Police) and I'm the next town over in Hudson. My house is pretty high on a hill. The scanner is up on the 2nd floor and I've moved it all over my house to try to get a better signal. I've had trouble since they split the Fire operations off to Londonderry (128.7450 NAC 652), but now I get nothing.
They are both P25 systems.
I've read the Easier to Read Manual ( Easier to Read Pro-651/652/106/197 - WS1040/1065 - PSR 500/600 Digital Scanner Manual ) tried everything I could find. I thought it might be the antenna so I bought a cheap window mount one thinking I could put it up even higher and a rubber duck 800MHz that gets less signal than the one that came with it.
I've been reading what I can find here, but I'm having a hard time figuring out what exactly I would need to make this work again.
I thought maybe the scanner was fritzing out since I've never had a problem before. I bought a Whistler 1065 since the manual programming was the same. It's doing the same thing so it must be interference somewhere or something. I've tried it with the Attenuator on and off even though I never need it on before. I'm so frustrated at this point.
I thought about putting an antenna up in my attic, but I'm not sure which way to go and everything seems pretty specific. I really only need to monitor 1 frequency so I thought I'd reach out to you all here and see if anyone could offer me some advice or point me in the right direction. I have no idea what the problem could be.
I hope I posted this in the right place and gave you enough information to help. Any help is very much appreciated.
