looking for suggestions
nursepen
south jersey
I have recently purchased the 396-t and I am looking for suggestion on what to program in it. I current have gloucester,burlington,camden,local airports, NJSP, philly fire, police,bucks,cape may conties programed in. I currently live in the south jersey area any suggestions will be welcomed.
elk2370bruce
East Brunswick, NJ
Please remember that the more frequencies/systems you have entered, the longer it will take to cycle through the memory channels. If you have a lot of them programmed, you might wish to increase the delay time. As others will tell you, there are always trade offs as well as pluses in any suggestion.
ampulman
South Jersey
Sounds like you're in a particularly good reception area. I'm in Voorhees and listen (try to) Philly with poor results (I've been playing around with a homebrewed yagi for 800 mhz which I hope to put on a rotor in my attic). If I drive 3 or 4 miles away, Philly comes booming in. I'm lucky to get 1 bar listening to Cherry Hill or Camden Police sytems and they have their share of static.
Before moving to my present location, I lived in Cherry Hill and could easily listen to Philly Int'l tower on a tuneable reciever.
Back to your question, you might try monitoring some utility sites like PSE&G, NJ Transit, etc. These can be interesting, particularly after bad weather. Speaking of weather, you might want to program weather alerts for any areas that you can receive, or routinely travel to. Another possiblilty is monitoring railroads (service search) and creating a system composed of local RR's (groups).
I created a system where I monitor the local EMS/Fire dispatch where I usually start my day to see what's going on in the area. If I hear of something significant, then I will switch on that area's police dept. I plan to expand that to include Burlington and Gloucester Counties.
K C 2 P B J mentioned about not having too many systems programmed, but increasing the delay time. This assumes that you have all your systems turned on.
As I indicated above, I start listening to one system and then add a system or group to include the police. I find that I rarely (if ever) monitor more than 1 system at a time. It all depends on my whim at the moment, and where I happen to be. For example, I find myself listening to Camden City late in the afternoon & especially weekend evenings (lot's of action). When I'm in range, I will turn on Philly, and so on. For variety, I'll tune in the State Police. Sometimes, I'll just pick a chunk of spectrum and search for new stuff. So, whatever turns you on.
I would be curious to know your location (town) and what your antenna situation is.
AM
mondaro
Harrison, New Jersey
I also have the 396T. I made it a statewide radio with every county in the state. trunked systems air, marine, etc etc. This way where ever I travel in the state I can monitor whats happening where ever I am traveling. A scanner in a car with the agencies along your planned route is priceless. I would invested in software programming this by hand can be a huge pain in the neck.
Tony
DJ88
Brick Twp., New Jersey
Just as a suggestion, if you haven't already done so, buy yourself a telescopic antenna for it (like the kind that come with the base model scanners). I got one for mine and it made a world of difference in the reception. The "rubber duck" antennas, like the one that comes with the unit, are, in my opinion, useless. There should be a BNC connector in a little plastic bag in the box it came in. Just unscrew the rubber duck and screw on the connector and attach the new antenna to it. Just make sure the telescopic antenna has the proper connector on the end of it. You'll get a lot more enjoyment out of your scanner with it.
ampulman
South Jersey
Tony
Excellent idea.
AM
