Loop v wire antenna
radioshane
york
Invergorden that is very close to the ground very short you're dowel was very low according to the man in the radio user it's fine right near the floor
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The Wellbrook is an 'active' loop, meaning it has a preamplifier. These are necessary simply because the loop itself is very small in relation to a wavelength at a given frequency on HF or MW - the amp makes the difference (yes, that's VERY much simplified).
That's what the power supply is for. Mike
radioshane
york
why did you put simplified ?
the man at wellbrook said that you have a antenna interface unit between the coax and the Receiver is
That right
and you do a coax cable first from the loop then to the interface unit then to the reciever ?
majoco
Stirrer
New Zealand
Get a look at the picture - the interface between the very low impedance loop and the amplifier are in the box at the bottom of the antenna - the coax goes between the box and your radio via the power adaptor which supplies power via the coax cable to the amplifier but blocks it from your radio - the signal still gets through.
invergordon
Palmerston North, New Zealand
@radioshane
With the power injector box comes with a 1 metre length of coax fitted with a BNC connector which attaches to your receiver.
You plug in 12v DC to the box so the box needs to be close to your power utility socket. When my loop arrived from the uK it came with a UK power pack so you need to check that yours comes with appropriate power or you'll need to supply your own 12v.
You will need an appropriate length of 50 ohm coax to go between the power injector box and wherever you choose to locate the loop. Mine was located 20m from the shack but I presume up to 100m will be OK, anymore and I think you'll lose some signal along the way.
radioshane
york
Invergorden. Would you say the ala 1530 LN , LF
Or normal 1530 would be the best ?
